TIA Sinamics G120 compare...
userxyz
May 2002
any
2,768
Small question...
Can you see if drives in a TIA project are equal to online in the blink of an eye or is a compare for each drive needed ?
I don't had the tools to test this, it's a question from a collegue,
Thanks,
Kind regards,
Combo
If there are differences in devicename or fimware version, it will show up immediately in TIA.
For the parameters, you have to run an offline/online compare.
That is my experience.
Hello to all, I have a STEP 7 project (v5.6) with S7-400F CPU and Sinamics S120 drives with CU320x2PN (ord. nr. 6SL3 040-1MA01-0Axx). I need to...
952
Hi all, I'm working on migrating some old Sinamics S120 drive units currently integrated in Step 7 5.6/WinCC Flexible 2008 RT to TIA Portal V14...
3,412
Default factory parameters. Sending 47F. But no action. Speed controller inhibited. Any ideas ?
2,629
Hello, Does anyone have any experience on configuring S120 with TIA and STARTER. I have 3 CUs. I have made the configuration at both ends, TIA...
3,818
Hello, good morning, I have been having two problems with the Tia Portal software. The first is that I have installed it on my computer and...
138
