Hi Everyone,
I am starting a new project using a Red Lion G308 connected to a existing AB SLC 504 PLC. This is my second project with the G308. First one was using a ML 1400.
Here is the hardware configuration:
Communications: TCP/IP Via 1761-NET-ENI
Slot 0: Processor SLC 5/03
Slot 1: 1747-SN RIO Scanner Module (3 LOGICAL FULL RACKS)
Slots 2-12: Digital IO
Questions:
Thanks All!!
Questions:
- Any issues connecting the G308 to the PLC via the ENI? I can get on-line with the PLC via the network so I know it works. What do I select in the Device Identification: SLC or ENI/Micrologix?
- I know how to address a PLC point in Crimson with a ML and add on modules. How should I address the RIO points? In RSL500 I can put a input in as I:1.1/8 or as I:1/24. How does it need to be addressed in Crimson 3.0 to get the HMI to work? My guess is I001:001 bit 8.
- Since this project is much more complicated than my last one I was looking at using folders to organize my tags in Crimson. Any issues with folders? Looks pretty straight forward but you know how that goes.
- Is there a way to copy Master Slides from one project to another? I would like to use the same Master Slide I used last project.
Thanks All!!
