GE 90/30 351 CPU, RS232 port
geniusintraining
Jun 2005
SC
8,287
Hello everyone,
I have a customer that is looking for a cable to communicate to the RS232 port (port 1) on a GE 351 CPU
Anyone have the pinout? he sent me a picture and it looks like he has an HMI on the other port(s)
Also is this port a RJ45 ?
Thank you!!
If you want to look it up the cable part number is IC693CBL316, it is also used on the 'station manager' port of an Ethernet module.
It is one of the 4 cables needed to work with most any GEIP PLC, the other 3 are:
AS693232SNP, or IC690ACC901 - (one or the other) 15pin RS-485 to 9 pin RS-232
IC200CBL500 - RJ45 RS-232 to 9 pin RS-232
Standard Ethernet patch cable, or cross-over cable.
Put them all in a zip-lock bag and label it "GE" :)
Thanks Russ, I sent the link to my customer... I think he is going to make them
Mark 🍻
I'm working on a 90-30 PLC which keep losing its program everytime it is powered down. We first figured it must be a battery issue, so we tried...
1,318
The PLC has a program in it that possibly programmed using LOGIC master, which I do not have. Prior purchasing "Proficy ME 8.5" I talked to GE...
3,040
I am setting up a bench practice unit consisting of a 5 slot rack (IC693CHS397C), POWER SUPPLY IC693PWR330C, cpu 351,and one input and one output...
3,878
Hi, could someone do a favor for me: I have a program in logicmaster 90 writen in SFC When I try to import program in PME I got an error, logic...
3,167
[/IMG] Can I use a usb to serial converter to connect to the cpu port 1 (RJ11)? And also which software do I need? Thanks
2,515
