GE 90-30 Comms between 2 Processors
reese006
Sep 2008
Birmingham, AL
21
Ok, I am needing to send some data from one GE 90-30 CPU374 to another one. Means would be over Ethernet. What is the best way to do this? I know in a Control Logix I would use a message instruction to message an array over. However I can not find something like that in the GE instruction set. I see where the processors support Modbus TCP/IP but again don't see an instruction that would read or write any data. Am I just missing it?
EGD is an option, however there is also the COMMS_REQ instruction that is equivalent to a message instruction in AB.
However....read up on on the COMMS_REQ manual, it's a ridiculous pain to configure.
EGD is the best option, however.
COMM_REQs are not really very difficult. They use between 5 and 10+ consecutive %R addresses. Based on the value of these registers the Communications Request knows what to do. One just fills in the proper values, from the manual, use a "1_Shot" to enable the COMM_REQ Function Block and watch for a "1" to come back to the programmed "Status" register. :)
The "Painful" part is that one must read the manual. (n)
Hello, can someone share/explain How to check comms between PC and PLC via TeamViewer? TIA
391
I had a comms fault between my VFD and Controller (5069-L320ERS2) that started about a month ago and happened maybe once a day to now where it...
291
Hi. I am having trouble establishing comms between an slc5/04 and panel view plus 7 via a PLX51-net-eni. The set up is: 5/04 Channel 0 DF1...
930
Hi, Does anybody have experience with Ethernet/IP-CIP Safety comms between 2 different brands of PLC's I have a project with 1 Safety Allen...
3,583
I was just wondering if anybody had any experience setting comms between Wonderware Web Studio and an Lantronics XPORT-EIP comm card. I’ve...
1,375
