GE 90/30 - RTU Master and Level sensor
piketooth
Nov 2005
Michigan
Need help with a GE 90/30-351 cpu , Horner RTM705 and MTS level Sensor .
anyone have any history writting ladder to commuicate with the level sensor using the RTU module ( RTM705).
Need to get this going as quick as I can ...
Cimplicity ME software
Could use some help .
Thanks,
Did you download the manual? You have to setup the Modbus comms using a Comm_Req command pointing to whatever data it is you want to get from the Slave device.
You can get the manual here.
Hi Guys, I am a new member and this is my first post! I have a little PLC experience but it is mostly with siemens logo and using ladder...
910
Currently I'm working in a project, and there is a problem, we need to show what is going on with the CR30 through an app developed in VB.NET, we...
611
Hello all, I am trying to setup my MicroLogix 1100 as a modbus RTU master for a modbus network containing multiple modbus RTU slaves. I currently...
3,943
I successfully got a Micro 820 (Slave) and Red Lion HMI (Master) to work together using Modbus TCP. But now I need to add an Automation Direct...
2,664
Hello, I am using the Micro830 (2080-LC30-24QWB) with the 2080-SERIALISOL in slot 1. I am having an issue setting up the Micro830 to communicate...
3,208
