Hi all
First project on a GE 9030 and would like some help with setting up comms to an ABB ACS550 drive.
Scenario:
10-slot rack with CPU363, CMM321 and various IO.
I'm using port 2 (as there are 2 drives) and have made up a cable as per the manual GFK-0356Q on pg5-22 as follows:
pin 1: shield
jumper pin 6 & 15
jumper pin 8 & 14
pin 7: grnd
pi 10 & 12: RS485 +
pin 11 & 13: RS485 -
On the drive side the terminals are labelled A (-ve) and B (+ve).
I'm aware of the settings in the drive but need to know what the settings should be on the CPU363 port 2 namely:
Port Mode, Duplex Mode etc and what logic function do I use to be able to read and write data to/from the drive?
Scenario:
pin 1: shield
jumper pin 6 & 15
jumper pin 8 & 14
pin 7: grnd
pi 10 & 12: RS485 +
