GE fanuc CMM 311 communication problem???
Jan 2004
22
I have a communication co processor module(CMM 311)installed in a GE 90-30 PLC.I have connected the PC serial port to the 25 pin port(tried with PORT 1 & 2) of the module using a custom cable.I am using versapro software.
1.Is it possible to establish connection between PC and PLC and to download ladder logic through a direct connection to this module?
if yes how?I couldn't establish a connection.The protocol setting and the serial port parameters seems to be matching.
2.Is there any free third party software by which I can read the register contents of PLC in a PC connected directly to the CMM 311 ?
3.When I tried to store hardware configuration and logic to the PLC flash,I 'm getting a message 'Insufficient privilege level'.The CPU passwords are disabled and the privilege level 4 is chosen.How can I get around of this problem??
thankyou
Abhilash
GE Fanuc CMM311 and VersaPro
1. Yes, all you need is the right cable and all Serial paramaters equal, you will not be able to upload the hardware config through this port.
2.Not that I know of, but you can use VersPro as a Server and collect the register information into Excel, directions for this are on the installation CD.
3.If your PLC has a switch on it, the default use of this switch is to protect from writing to Flash, turn it to the "OFF" position and it should work.
Hello! I have a question on controllers GE Fanuc 90-30. On the automatic line are using 2 controllers 90-30 . Each of them is connected to...
2,055
I have a GE 90-30 PLC with a communication co processor module(CMM311) installed in it.Is it possible to connect(and see registers) the PC with...
11,092
I have a CNC cutting equipment, all the components are Fanuc from the CNC CPU A02B-0307-B822, a PLC AIF01A and a panel i, on the panel i (operator...
115
I want to buy this program if anyone has it. Absolutely no one has it officially for sale. My cpu is IC610CPU104B My mail...
114
I've got a Micrologix 1100 with ethernet and I'm trying to configure communications to a Fanuc R30iB controller. I'm pretty sure you have to set...
106
