GE Fanuc HMI Development
Phil Bugg
Dec 2003
Macomb, MI
Does anyone have any experience developing a PC Based HMI for GE Fanuc 180i or 160i controls using Visual Basic. If so, what VB controls are available to use. I am currently investigating using VB or using Cimplicity from GE Fanuc for this development. I am thinking of the cost savings and versatility of using VB but am told by GE Fanuc that the simplest way is using Cimplicity.
GEFanuc offers a product called Cimplicity HMI for CNC. It is an add-on to Cimplicity Plant Edition. Part number IC646NCN010. It communicates with the CNC controller via GE Fanuc's proprietatry HSSB (High Speed Serial Bus), so you need a HSSB interface card in your PC.
That's probably what the Fanuc rep is recommending.
The problem with writing your own interface with VB is that Fanuc does not publish the details of their serial protocol. There are a lot of Fanuc CNC controllers out there, so there may be some third party ActiveX or OPC controls avilable that you could integrate into your application. I've never investigated along those lines.
Using Cimplicity will mean higher up-front costs, but will assure you of a level of support so you can get your application running in a reasonable amount of time. If you try the VB route, there is a good chance that you'll burn up any initial cost savings in additional development hours.
You get to flip the coin and make the call.
Hello All, A coworker and myself are currently trying to figure out how we would read a register on our fanuc robot though our crimson G306 HMI...
473
I have read every post I can find on how to interface an Automation Direct C-More EA9 series HMI to a FANUC robot with no luck. Some say it is...
3,092
i got one and it has nothing inside, application software. i feel there should be some kind of application to run the HMI logic. i want to...
949
any one worked on this QP ge fanuc?i got one and it has nothing inside, application software. i feel there should be some kind of application to...
1,237
2,515
