GE Fanuc Nano Serial Communication?
madmanex
Mar 2005
I am trying to use the serial port on a GE Fanuc VersaMax Nano to communicate serially. Using the COMMREQ command I can change to serial (RS-232) mode when I am in run mode and the PLC automatically switches back to SNP mode when the the PLC is switched to stop. At this time I can reconnect my programming PC to the PLC.
But if I try changing the serial port settings, like baud rate or parity, when I switch back to run mode, I am unable to connect the programming PC to the PLC.
I also tried saving everything to flash memory and now the PLC is in some indeterminant state where I am unable to connect to it at all with the programming PC.
Is there some way to erase flash memory on the VersaMax Nano? How do I handle serial communications so that I can change the baud rate and parity in the ladder program while running but still allow the port to switch back to default SNP when stopped?
Joel
In my college we have nano (ge fanuc) (10 point) plc with one analog i/p.IC200NDD101. now what I want is how to talk to it? I mean read / write...
1,473
Hello, i am using profibus as communication between plc and fanuc arm. I can easily send inputs from plc to arm, but i can't monitor any outputs...
40
I have a CNC cutting equipment, all the components are Fanuc from the CNC CPU A02B-0307-B822, a PLC AIF01A and a panel i, on the panel i (operator...
126
I want to buy this program if anyone has it. Absolutely no one has it officially for sale. My cpu is IC610CPU104B My mail...
118
I've got a Micrologix 1100 with ethernet and I'm trying to configure communications to a Fanuc R30iB controller. I'm pretty sure you have to set...
110
