GE Fanuc series one and plus
atatari
Sep 2002
92
Hi everyone!!
I am using series one and series one plus GE PLCS,
I have heard that the programming for these plcs are different.
series one is 101/102/103 series one plus are 105/106/107
Does anyone has know where I can find the differences.
we normally use logicmaster or tisoft to view and edit the programs.
I have 101 series which are old and hard to find the spare parts ,so I am considering upgrading them and I need to rewrite the whole program.
Thanks,
The Series One Plus added more functions and additional I/O points. Any program written for a Series One is transportable to a One Plus. I believe that when TI picked up the product line, they only offered the equivalent of the One Plus. The same would be true of Automation Direct.
Perhaps Direct Soft from Automation Direct can import Logicmaster or TISoft files???
Replaced ASCII/BASIC module but can't get reloaded.
1,457
Has anyone worked with on of these PLC's? If so, how do I connect to one? What software do I need? What cable do I need? I'm looking online...
665
Got an old machine with a IC610CPU104 CPU. A bit of research told me this is the same as DL305 so DirectSoft from AutomationDirect should work...
2,087
Dear Experts I need to connect to this CPU 374 It seems it is a GE Fanuc PLC I want to know if I will require any specefic cable - from the...
1,814
Is there any way to make a connection directly between a GE Fanuc 90-30 and a Mitsubishi FX Series PLC? If there is no means to connect directly...
21
4,253
