GE Machine Edition Ver 9.8
jimdi4
Aug 2004
108
Hello,
I am new to GE (Emerson) Machine Edition ver 9.8. I have a loaner processor until i get the one i ordered, model IC695CPE330, i am trying to connect to it but get:
Error 8071- Invalid IP Address
Error 8500 - Could not connect to device.
Since it probably had an IP address in it already, it doesn't match what i put in to the PLC program, i get that, but how can I either Reset CPU to factory default or reset the IP address in the existing CPU?
I found below website that showed a Machine Edition version where they had you go to the "tools/utilities" tab at top, but my version only says "Utilities"
https://controllogic.com.au/blog/po...the-set-temporary-ip-address-tool-in-2-steps/
I dont have the capability to set temp ip address.....Any thought comments appreciated..and thanks in advance...🔨
The CPE330 has a default address of 10.10.0.100. You should set this as the address to connect in the Inspector.
Once connected, start your download. When the hardware configuration has loaded, you will be disconnected.
Change to your configured address in the Inspector, reconnect and start your download again.
Here is a link to the CPU reference manual from Emerson. Section 3.4.1 is "Establishing Initial Ethernet Communications".
The 10.10.0.100 address is for a new, fresh out of the box CPU. If the person who loaned it to you set a different IP address you'll need to get it from them. I'm pretty sure the IP address is saved in flash memory so it won't be cleared by powering down with the battery removed.
Hello, I am new to GE (Emerson) Machine Edition ver 9.8 I have a loaner processor until i get the one i ordered, model IC695CPE330, i am trying...
2,427
To my surprise, InduSoft has been rebranded to InTouch Edge HMI. After the IDE software install, I instantly thought I mistakenly installed...
2,667
Hi, I'm new to ME and QP+ and have what are probably some basic questions about communicating between a PC and an HMI. I am running ME version 8.5...
3,626
I'm getting frustrated creating arrays of variables in Machine edition. I need to make 2 variable arrays that are 102x2 in size, with varying...
126
I have an issue. I am trying to resolve what logic is in a 90-30 PLC (364 CPU). I have 3 Machine Edition backups with different names. All show...
160
