GE Proficy ME latest version?
Webhead
Jun 2005
Central Florida
145
Can someone tell me the latest version of Proficy Machine Edition? I had a contractor use 8.6 and we have 8.0 so I am unable to load his project let alone download anything if I need to. Thanks in advance.
That or if you have the 8.0 backup and the Contractor didn't make a many changes you could replicate his work... otherwise upgrading is your only.option
Has anyone migrated Proficy Historian data to a new server? I followed the guide to move all the data over, but when I run the utility, it stops...
50
I'm getting frustrated creating arrays of variables in Machine edition. I need to make 2 variable arrays that are 102x2 in size, with varying...
105
Hi I am wondering if the RXI-042 PLC model (below PN) is programable via Proficy Machine Endition, if so, what is the firmware version needed for...
98
Greetings, I am working on a project and I would like to scale %AI to -10.0 to 10.0 VDC. The module Input data is stored as a 16 bit Integer and...
73
I am trying to download a program with usb to serial cable in rx3i IC695CPE305 while logic and configuration is equal but when i start downloading...
48
