GE Quick Panel View
dobidust
Sep 2011
Middlesbrough
44
Hi Guys
I wondered if anyone can tell me what the fastest update rate is for the quick panel view HMI's. I have a bool that is flashing at 250ms on 250ms off but the screen is not detecting the change at all my settings are as seen attached. Any advice would be great.
Drew
The update rate depends on how many variables you are trying to read and how they are arranged. If you're using addressed variables you can get significant improvements in update frequency if they are consecutively addressed and all of the same data type (%R, %M) even if that means adding some rungs of ladder logic to copy variables.
I doubt that many screens will reliably blink at that rate even with a fast Ethernet connection.
BTW, "Target Scan Time" refers only to the Logic when running the QP as a controller.
The screen update rate is set in the 'PLC Access Driver' via the "Scan Rate" parameter, fastest is typically 50ms.
I am trying to set up the Target Viewer Utility for Quick Panel View and am able to connect to the HMI. It gives the following info when...
1,894
I am trying to write a panel script to reset a registry file in the plc at a set time of day. I am not sure what script functions to use
1,404
Hey, I have no experience what so ever with Quick Panels. I have Proficy Machine Edition 5.50 Software on my lap top. I have the Cimplicity...
1,872
1,887
I have a PV1000 Color Touch 2711-T10C10 and it has the DeviceNet option card. I have found a DH+ comm card for the same type of PV. My question...
1,737
