Quick panel view Registry reset
GARRYA
Sep 2012
USA
I am trying to write a panel script to reset a registry file in the plc at a set time of day. I am not sure what script functions to use
I'll bet you mean a "memory register", rather than a "registry file"; the latter would be part of a Windows computer.
Are you working with a "QuickPanel", or a "PanelView", or something else ?
The more you can describe about your product and application the more specific advice from the Forum can be.
I am working with a 6” “QuickPanel View” GE
and yes Memory register in the plc
First decide if you will be using the clock in the QPView or a PLC.
If using the QPView clock: Then decide if you are going to use a VBScript or a View Script.
Next open the Toolchest and select the Drawer "View Scripting" now open the "Companion" window so you can view both windows. Now click the '+' next to the type of Functions you selected. (VB or View)
Select and look at the Date and Time Functions and see how each works in the Companion Window.
If using the PLC clock in a GEIP PLC look at SVC_REC 7 in PME online help.
Hi Guys I wondered if anyone can tell me what the fastest update rate is for the quick panel view HMI's. I have a bool that is flashing at 250ms...
1,501
I am trying to set up the Target Viewer Utility for Quick Panel View and am able to connect to the HMI. It gives the following info when...
1,894
Hey, I have no experience what so ever with Quick Panels. I have Proficy Machine Edition 5.50 Software on my lap top. I have the Cimplicity...
1,872
1,887
I have a PV1000 Color Touch 2711-T10C10 and it has the DeviceNet option card. I have found a DH+ comm card for the same type of PV. My question...
1,737
