GE RX3i IC695CMM002/004 serial I/O comm rs-485 problem
ghowno
Aug 2010
Zabrze
Hello!
At first I want to ask you a question:
Anybody could help me with communication by RS485 from ASCII device to Rx3i CMM004 module. I'm using GFK2460C manual about serial communication in Rx3i, but it doesn't help in my case.
I'm doing everything like in manual, but there is description about Serial I/o by RS232 - in RS485 should be easier but it doesn't :/
I stack in this moment - I'm receiving data from RX3i (Rx3i transmit it), but when I'm trying to send data, I got receive error (from RX3i status bits).
I have configured port like in image.
Can anybody send me example for communicating by RS485 with this module (it doesn't use COMMREQ) or have answers for my problem?
When I sending to RX3i I'm switching only 2bit of port control data, to receive I need switch only 1bit of port control data?
Please help me :)
There is no way to tell you exactly what is wrong. One needs to understand the device on the other end in order to properly configure and use this module. If you do not understand the manual, what specifically is confusing you? Please get GFK-2460E, or newer, just make sure that you have the latest version from the GEIP Support web site and are you sure that it is properly wired? While at the web site you should also verify that you have the latest firmware version in your module.
Also I made this spreadsheet for one of my customers, it may help.
Hi all I am trying to communicate modbus from this comm module and am having some issues (can't get it to work basicaly). I have followed all the...
5,513
I have a system using Rx3I CRU320 redundant CPU with Proficy Machine Edition Software. In the hardware configuration of each CPU module, under...
391
Hi, we are using Rx3i CRU320 redundant PLC system and we noticed a discrepancy between Primary and Secondary controller. Couple of variables (DI)...
285
Hi there, I'm doing some extensive testing and commissioning with a slew of new Emerson PACSystems RX3i PLCs. It would be convenient to...
108
Hi there, Trying to get some ascii serial communications working via RS485 (COMMREQ functions). I have attached our wiring for the COM2...
980
