GE Versamax PLC going onlline
ceilingwalker
Mar 2010
Phoenix, AZ
1,586
Good day all. I am trying to go online to upload a project that is in a GE Versamax Micro (IC200UDR140-DC) using a cable (IC200CBL500A) and a serial to USB converter. I have no experience with this software and loaded it new today. The PLC that I am trying to upload from has been in place for about two years. I have read the book that came with the software and looked at a video on Youtube but I still can't get this to go online. I attached to screenshots to show what is happening. It appears to attempt to go online and then pops-up the error.
Be sure that your USB adaptor is using the port shown for PME to use.
The default parameters are 19.2 k baud, Odd parity, 8 stop bits.
Was there a modem attached to the PLC? Then try 9600 baud, No parity.
If you have the proper project the hardware config will tell you for sure what parameters to use.
I will try it again. As far as the modem, no. It is USB to processor.
The IC200CBL500 connects to port 1 on the PLC. You showed a screenshot of the configuration of port 2. The "Port Mode" parameter for the PLC port you're using to communicate should be "SNP". If the file you opened is accurate and the port configuration is not "SNP", you may need to connect through a different port. A configuration of "Serial I/O" is typically used when you need to connect a barcode scanner or some other serial device to the PLC.
When you display the properties of the target in Machine edition, one of the fields is labeled "Physical Port". Make sure that it is set for the same COM port as your USB/serial converter.
Hi, The VersaMax PLC suddenly stop running (no LED on run function) so I'm trying to upload the program. The HMI connected to it says "Host...
140
Hi, I am trying to set the IP address on the IC200UEM001 Ethernet Option Module. I am following the procedure in the manual for setting a...
439
Hello! Our PLC stopped working.(Controller CPU hardware failure) What can we do? https://prnt.sc/txskqe
1,811
I'm trying to utilize a PLC that my employer already had on hand for a project. For the life of me, I can't figure out how to get my computer and...
5,223
Every time i turn off and turn on the PLC, PLC is not going to RUN mode In the fault table it shows error " system Configuration mismatch" And...
1,762
