GE Versapro counter ?
jcraft
Dec 2006
Niagara falls
91
Okay, so I was on line today doing some troubleshooting with a 90-30. the Program has a rung with an up counter in it. there is a contact on the rung tied to a proximity switch for motor shaft. While the shaft is moving the switch is transitioning about every second and the counter is counting this. I noticed that looking at the data watch table for the prox.input and counter, the input shows a constant 1 and the counter keeps counting in the table. I physically looked at the prox. switch and the led on the prox. is flashing about every second. I am assuming that this is just a matter of the program not showing the data quick enough in the table to uopdate it so it looks like it is always on. Just wondering because the counter is supposed to increment when the enable switches from off to on and so on. Also, has anyone ever heard of a memory location wearing out and the data sometimes getting erroneous. Thanks
What you see is a screen update "thing", watch long enough and you will likely see it go off once-in-a-while. When a memory location "wears out" you will get a a parity error and likely will need to replace the device with the "bad" memory.
V
hi everybody, i am an M.Tech student.my project work deals with GE FANUC PLC.I'm also learning about AB PLC as a part of training.as in case of an...
5,723
I have a LM9030 program that is running on a IC693CPU331 that was installed in the mid 90's. How can I find out if this cpu can handle newer VP...
1,282
I have a Versapro project file for a Versamax PLC. Need to identify what type of variables are suitable and made available for BMS system to...
1,716
I was given a file with a .SwxCF extension. Can this be opened in any way with VersaPro? I only have version 2.0 Pro and have no luck. I think...
1,957
I have GE Fanuc VersaPro 2.0 software where can I get an upgrade CD. I need to program a IC200UEX164 64 point (40) 24Vdc In; (24) Relay Out; and...
26
2,232
