GE VersaPro Install Issue
Byron
Apr 2004
Caruthers, California
257
I have an issue with VersaPro (GE-FANUC) I've used it for YEARS- the 4 day demo, re-install... a while back it would not re-install. The setup.exe appears in the task manager (WinXP) and then freezes. I Googled it and hundreds, if not thousands of folks around the world have had the same issue with various program installations involving "Install Shield", with no real resolution that I have found (looked for months online). I, like others, have done thorough cleaning of registry; un-installs; on and on... no solution yet except for the dreaded reformat of the HD. That is NOT an option for me. For now I just use another of my laptops. Just wondering if anyone can shed any light on the issue with Install Shield- it only affects VersaPro on my XP machine, but other folks have the problem with various software installs. Install Shield was no help that I have seen for anyone.
[email protected]
I had an issue a few years back with updating my Proficy. GE Fanuc (now I-P) tech support sent me to a web page with some things to try to get the install to work. I will attach a PDF printout to this post.
I suggest that you upgrade to Proficy ME, as you said VersaPro is really OLD.
Also maybe it is time to purchase the software?
I have a LM9030 program that is running on a IC693CPU331 that was installed in the mid 90's. How can I find out if this cpu can handle newer VP...
1,276
I have a Versapro project file for a Versamax PLC. Need to identify what type of variables are suitable and made available for BMS system to...
1,712
I was given a file with a .SwxCF extension. Can this be opened in any way with VersaPro? I only have version 2.0 Pro and have no luck. I think...
1,957
I have GE Fanuc VersaPro 2.0 software where can I get an upgrade CD. I need to program a IC200UEX164 64 point (40) 24Vdc In; (24) Relay Out; and...
26
2,229
Needing a bit of help on some GE Series 90-30 configuration files. It appears that I need the GE VersaPro software at a minimum to view the data...
2,426
