GE9030 CMM321 to SCADA!
markm@sencom
Apr 2007
Perth
Hello,
Is there any program logic required for a cmm321 card to allow SCADA to talk to it?
I have configured the IP address of the card...can ping!
the SCADA driver returns a connection refused!
Please HELP!:mad:
Mark....
The SCADA package is MacroView see www.sencom.com.au
The driver does talk SRTP and it is our own, we are porting it to Linux, and would like to run some tests. It currently runs on SCO, Solaris and Windows..
Mark
You should not need any ladder logic to support SRTP.
You say you have configured the PLC. Presumably you did that through the serial port. After having done that, are you able to connect your PC programming software through the ethernet module? That verifies the physical connection. If the programming software communicates properly then the problem lies in the implementation of the protocol in the driver.
I am using v6 Logic Master software, and have only connected through the serial port. and then directly with the driver to the cmm321...
Can you connect to ethernet via Logic Master?
Cheers
Mark
Release 6 of Logicmaster is pretty old, dating back to 1996. Is your 90-30 hardware of the same vintage? Support for ethernet communications was evolving rapidly around that time. The manual GFK-1029b gives instructions for setting up Logicmaster for ethernet communications. The manual GFK-1541b gives information about installaing the CMM321 in a 90-30 system.
You can get manuals here:
http://globalcare.gefanuc.com/
Click on "Product Manuals - No Login Required"
I'm servicing a machine with a IC693CPU313W CPU. This is the low cost embedded type. Per Steve Bailey's post # 2 here in this thread, I can't use...
1,222
Here there, I am working on a project to send Gefanuc 9030 PLC data via its CMM311 card to put on a radio telemetry link to be sent to another...
1,486
I want to establish communication between two Gefanuc 9030 Plcs using two respective CMM311 cards. I have selected CMM only protocals with RS323...
1,276
Can the 9030 software run in the XP enviorment? Have a customer thats needs some debugging. I haven't talked to a 9030 in many moons, last...
1,930
Hi all, I am using a GE 9030 /CPU311 and a PBM200 Profibus module. I have a distint blinking patten on the PBM LEDs but cant find any info in...
2,372
