gearing for analog drives with C240
Kataeb
Jan 2007
www.livelovelebanon.com
636
We want to do "angular synchronization" (gearing) for 4 old Dc Drives, which should follow a Main Master.
We have the following: 1. SIMOTION C240 (6AU1240-1AA00-0AA0). 2. MMC (6AU1720-1KA00-0AA0). 3. MULTIAXES license (6AU1820-0AA24-0AB0).
Each Dc Drive has: 1. TTL encoder for actual position reading. 2. Analog input for speed setpoint.
The Main Master has also a TTL encoder.
Question: Can the C240 do the angular synchronization for 4 dc drives with analog setpoints? Where the Position Loop will be done? Which additional hardware or software is needed? Thank you
yes, you can do angular synchronization. The position controller is in the C240. I didn't check all your part numbers but it looks complete
...But I hope you have high performance digital DC drives...
Has anyone done any electronic gearing using a Nidec 750 series drive? I'm looking at a couple of configurations, but unsure which to go.
770
1756-L82ES controller, V33 lastest firmware using a Sick brand encoder to monitor position on the shaft of a conveyor. (call this conveyor) I...
1,220
I have set up a 755 with dual encoder board to follow a filler drive motor position on a bottle filler and capper machine. The master encoder is...
1,215
Kindly, what do they mean by the below "..." ? We frequently use Motion Axis Gear (MAG) with an incremental MAM instruction . What happens if...
1,427
We are pretty new at servo motion and control. We have used a Kinetix 300 controlled by an absolute encoder wired directly to the drive, but have...
5,178
