Get the program from Micrologix 1400 using CCW
nuwan
Sep 2013
Moratuwa
30
Hi! We need to keep a copy of the program of our packaging machine AB PLC. Would I be able to read the program of a Micrologix 1400 PLC using CCW?
Thanks in advance.
RSLogix Micro Starter is the least expensive option for you. RSlogix Micro Developer includes basically the same features as RSLogix 500 Standard but only works with Micrologix PLCs. The Starter version doesn't do online editing, cross reference, and a handful of other handy features, but can still get online and save files. There is a "Starter Lite" version that is free but will only work with Micrologix 1000 and Micrologix 1100 PLCs.
RSLogix Micro Starter 9324-RLM0100ENE $151
RSLogix Micro Developer 9324-RLM0800ENE $540
Thank you for all your answers. Thank you OkiePC for your detailed answer. I believe purchasing RSLogix Micro Starter 9324-RLM0100ENE goes with our requirement this time.
We have a PanelView C600 HMI as well. Can we use CCW to get the program of it ?
nuwan said:
...We have a PanelView C600 HMI as well. Can we use CCW to get the program of it ?
As of CCW v6.0 you can only perform Download to a PanelView Component HMI terminal. You cannot perform an Upload. You must use the built in web browser as JohnCalderwood has mentioned.
Just to confirm and provide a little more detail on John's good advice...
594805 - File transfer methods for the PanelView Component when working in CCW
Access Level: Everyone
Regards,
George
Thank you JohnCalderwood and Geospark.
I accessed the PanelView C600 HMI through Ethernet. I found the IP address of it using Advanced IP Scanner freeware (https://www.advanced-ip-scanner.com/ )
Chrome didn't support, so I had to use Firefox. I stopped the running program and plugged a USB drive to the USB port and copied the program.
The procedure is different than most of the other HMIs that we use. In this part of the world AB is not that common although we love the brand so much.
Thank you for your help, I appreciate it very much!
Howdy Everyone, We have a micrologix 1400 that keeps dumping the program every couple months. we are not getting a battery fault or anything, just...
1,502
Need help--I use RXlinx clasic 2.34 --who is online connected to Micro Logix 1400. Read out Program Name and showing note is "1400" But When open...
2,358
I have received Micrologix 1400 plc as a replacement of Allen Bradley micrologix 1000 from my vendor. Now i need to download the program through...
5,436
I have an application developed in Rslogix500 for a Micrologix 1400 but for some reasons i now need to use a Micro850 but i dont want to spend to...
2,880
Hello Sir, I m new for DNP3 comunication in AB. The following things i did in my program . We are doing DNP3 slave in Micrologix 1400 channel 2...
3,613
