RS Logix 500 cannot upload Micrologix 1400 Program
nulizhang
Oct 2014
Brampton
Need help--I use RXlinx clasic 2.34 --who is online connected to Micro Logix 1400. Read out Program Name and showing note is "1400" But When open RX Logix 500 (ver.8.0) to read program out--there is jumped an message "This is SLC 500 program"o_O
Are you sure about that version of RSLinx Classic ? Version 2.3x would be about fifteen years old. What operating system are you running ?
Try creating a new project with your RSLogix 500 software and see if the MicroLogix 1400 Series A and Series B are selectable. If they aren't, it's likely that your software needs to be upgraded to support your MicroLogix 1400.
RSLogix 500 version 8.3 is required to support MicroLogix 1400 Series B. I'm not sure when the original Series A support was introduced.
Downloaded RS Logix 500 , now cannot open Rockwell Software"Error Logging Security" I have RS Logix 5000 and Factory Talk View Studio , and it...
10,483
I have a Micrologix 1500 that I cannot connect via micrologix/rs232 DF1 cable/driver. I have tried 3 different laptops, tried direct connect with...
5,291
i cannot uninstall RSlogix 500 v9 from laptop. in control panel, remove window stays freezing for days. i tried to reinstall it to get the new...
3,545
This error is inconsistent. Most of the time I try to open RSLogix500 it gives me the error along the lines of "Server busy, action cannot be...
19,135
I'm trying to simply change a timer preset value from 100 to 500 (x .01 sec) using RSLogix 500. It allows me to highlight the value and type in...
7,943
