get value on ignition software from EL3403
usmania
May 2014
munich
i configured ignition software with beckhoff embedded PC CX8091 through OPC-UA. Now i connect EL3403 with CX8091. I want to measure the values of voltage, current and power through this on my ignition software. Will you please guide me how to program the CX8091 in this regard, that my measured values should be shown on software that i am using. thank you
regards,
usman
Bring the EL3403 into your system manager project and link your variables to the hardware.
for example declare a var
Voltage AT %I* : DINT;
Current AT %I* : DINT;
ActivePower AT %I* : DINT;
in your PLC code then scan that PLC project in system manager and link to the inputs.
I cannot add SLC500 analog input tag (I: 8.3) to EZSeries Touch Panel Editor (V 5.3). I used all the listed tag datatype but it all says "Invalid...
261
I want to set user security level based on the value of a tag in my PLC called "ActiveUser". That tag will contain the A-P code which we use for...
226
hello. In Intouch, I want the color of the alarm window in the header menu to change depending on the priority value of the tag. To do this, I...
86
I have a Type C to RS485 adapter connect to my Siemens RWF55. I use modscan to scan it to get a value from the Siemens controller. In the...
106
I'm pretty new to PLC's, so forgive me if I use the wrong terminology and whatnot. We have an issue at work where we have a flow meter that is...
297
