I am getting the below mentioned error while updating firmware of MLX1100B using control flash software. The error is as given below
11/09/12 01:52:53 [FAILURE] Update: Command ignored, controller is not in the correct state.
DTL_E_FAIL, I/O completed with errors
11/09/12 01:52:53 [FAILURE] Update: Error Code: 24 Extended Error Code: 523 Context: 4
11/09/12 01:53:02 [FAILURE] Update: Instance = 1, Size = 490900 byte(s), Chunk Size = N/A.
However I have controller setup in PROGRAM mode only.
Help in correcting this and updating firmware properly in MLX1100B.
