ghost nodes on dh-485
MNJ96
May 2005
Salem, Oregon
50
hi everyone
this is in conjunction with a active thread i have going SLOW PANELVIEW . i changed my slc/03 program to enable df1 pass thru option to my connected panelview 550 . also changed the max node address from 31 to 4 . it worked fine being able to connect to the panelview thru the pass thru but after i changed to max node addresses and downloaded the program. now in linx i no longer can see the panelview and i am showing the same processor and program on all 32 nodes . if i delete a node it comes right back and i also can not stop or delete the df1 driver despite all my efforts has anyone seen this before ?
thanks
Now that you have jogged my memory I have seen something similar using
a KF2 box ( RS232 DF1 to DH+ converter) but that was several years ago. Much older ver. of RSLinx.
Do you have the latest ver. of RSLinx?
You should be able to delete the DF1 driver. You may have to uncheck the autobrowse and physical disconnect then try to delete. Or restart RSLinx without any connection and uncheck autobrowse then delete. Then restart RSLinx again.
I think that "ghost nodes" effect has to do with the Pass-Through function and the Device Type that you have selected in RSLinx.
When you select "KF3/KE" as the Device Type, the RSWho browser sends indentity requests with all possible node numbers in the destination field.
If the SLC isn't properly configured for passthrough, it answers those requests itself (it ignores the Destination field), thus every node number appears to be the same SLC.
Some of the "pass through" functions are not perfectly labeled and are easy to misunderstand. Post exactly which Status table bits you have set and cleared, and post the precise RSLinx configuration.
Guys I know this may not be a PLC question but I do have a issue that I was needing some advise. I was needing to know the best way to create a...
1,947
I need to ghost this machine. ALLEN BRADLEY 1500P Cat 6181P-15A2MW71AC MAT N0 PN 337626 DIR: 10002125617/00 20FEB2017 Windows 7 Professional I...
1,360
Can't take credit for this, a friend had seen it. But Rockwell, etc. were all lost. Relay output card. Large rack. LOTS of outputs. Output...
1,471
Hi everyone, had an odd occurence happen and wondering if its ever happened to anyone else in their field. Programming a GE RX3I with...
1,868
While creating a runtime, the progress window shows: compression Tag\ABC1_ABC.db.wat The ABC1_ABC is a project\target\tag\???? from a previous...
1,564
