good afternoon,everyone,for the JSR INSTRUCTION
Feb 2007
Richmond Hill, Ontario
40
I am trying to use the JSR instruction to control 2 defferent sequences, it requires sequence 1 continously running when selector switch is on after start button is pressed.
and sequence 2 will continously running when selector swithc is off after start button is pressed.
but,changing the selector switch after sequence starts will have no effect.
my question is that how to achieve the requirement of changing the selector switch after sequence starts will have no effect when using the JSR instruction?
You could have two bits enable-jsr1 and enable-jsr2.
selector switch and start and not enable-jsr2 turns on enable-jsr1, which retains itself until either sequence is complete or stop.
not selector switch and start and not enable-jsr1 turns on enable-jsr2, which retains itself until either sequence is complete or stop.
edit: 1st post with new hometown and country :whistle:
Try this (or something like it), just remember that you need to unlatch them at some point
My Feeble Attempt.
To Stop the Sequence (SUB one or SUB Two from running you will need to unlatch B3:0/0 in rung 0 of MAIN.
504Bloke, Advance to Go and collect your salary.:D
GIT, go directly to jail! :eek: Your program does not seem to prevent the selector switch from switching between the two routines.
My get out of jail card is bold :D ....
must have disclaimers :p
EDIT: I read it again, I still dont see where the OP says I only want one scan to run at a time????...
Automation,
Did you do it like PeterW and 504Bloke showed you? I think it should work. Which requirement could you not get?
Lancie1 said:
504Bloke, Advance to Go and collect your salary.:D GIT, go directly to jail!:eek: Your program does not seem to prevent the selector switch from switching between the two routines.
I thought GIT had put that in as a deliberate mistake :)
I didnt feel it my place to knock his confidence ;)
EDIT for GIT: "changing the selector switch after sequence starts will have no effect."
automation.robotics said:
the way you said here, I tried, it seems that only can acheive the requirement of one sequence, that other sequence rquirement can not get it.
I didnt test mine but cannot see why it shouldnt work......
What doesnt work exactly ?
Has anyone had experience or tried to run a 1200 siemens plc through tia portal v14, using the SCADA or pc system or pc station to control it from...
2,221
I have a job that I'm working on that needs to have some RFID implemented. I have some experience with RFID from past work, but not quite in this...
1,128
Why does everyone hate Connected Components Workbench? Are there legitimate reasons or is it just because most controls engineers are Luddites...
28
16,296
So I'm on here a lot and I see a lot of people from all sorts of industries on here posting and from my experience in the field, I've seen PLC...
37
9,507
I don't get around the forum as much these days, but just wanted to take a moment and wish you all a Happy Thanksgiving. I am at work, thousands...
2,554
