PeterW
504bloke said:Whats it like so far over there ?
wet and cold
PeterW said:wet and cold
Kim Gold said:Also keep in mind that when using JSR instructions that if you turn an output on or off it will remain in that state while subroutine is not being scanned.
Kim
geniusintraining said:Welcome to the other side of the pond Peter , remember we drive on the right side of the road
504bloke said:My Feeble Attempt.
To Stop the Sequence (SUB one or SUB Two from running you will need to unlatch B3:0/0 in rung 0 of MAIN.
504bloke said:Put the stop button in the BRANCH on Rung 0 of Main after (or Before) System Started (B3:0/0).
This could be an Input (ie Push Button) or a B3 bit that is turned on/off from within the Subroutine/s from a Stop Input.
Like This
automation.robotics said:you put stop there, the output will stop also, will not stop at the rest position of current cycle.
Lancie1 said:Try this tested program.
