Gppwin Developer
Nedflounders
Jan 2006
east anglia
I use the above software to write small programs for mitsi. A1s modules.
I would like help in understanding some of the ladder logic.
Unfortunatly I don't have a copy of the logic I need help with.
I have an analogue input (flow meter) 4-20Ma wired to an analogue card. I have contacts for a watchdog and ready for a\d conversion but then have
[from h8 k10 w100 k1]
I guess [from h8] is identification of which analogue card it is to scan since there is more than one and get the W100 being the 4-20 raw value input but don't know the rest of the code.
Could someone please point me in the right direction.
Thanks Ned
If my memory serves me right the instruction is as follows:
H8 is the address of the card,K10 is the start of the raw analog values W100 means store it in the word 100 (if you fetch more than one it populates the next consecutive words & K1 is read one analog value
so if you had a 4 input analog card & put them in W100 & read K4 it will populate W100 to W103 with the 4 analog values.
All special function cards on mitsi use the To & from instruction, the writing & reading of data either sets up the card, sends data to the card or receives data from the card, each module has a buffer area that you address using Hxx.
e.g. buffers 0 to 3 might be for setting limits on the card 4-11 might be the 8 channels of data read & 12-20 might be diagnostic data you can use in your program about the card.
My IT dept' purchased a new laptop for me, a Toshiba Tecra. It has all mod' cons' and a serial port too. Any how they removed Vista and re...
3,357
I'm trying to verify a project with a PLC. The Transfer Setup menu item is grayed out and every time I click Verify with PLC, I get an error...
75
Well, I've decided to start a new project, and like all projects, it has already gone horribly wrong. I purchased a PLC device (supposedly a...
125
Does anybody have any samples of how to "Create and Use" UDT's in CCW Developer Edition? (I am using v22) I can't find any information from...
329
I'm trying to manually convert a Beijer E200 HMI project onto to a new Mitsubishi GOT gs2107-wtbd. The PLC is a very old A-series AS1CPU and is...
396
