New laptop problem with GPPWin
Badger
May 2005
Redditch Worc`s
410
My IT dept' purchased a new laptop for me, a Toshiba Tecra. It has all mod' cons' and a serial port too. Any how they removed Vista and re installed XP (I believe GPPWin will not work with Vista).I have installed GX developer V8. The problem is, When i try and connect to a plc I get a message [insufficient memory close other applications and assure suficient memory is available]
<ES:0180800a> The laptop has over 1G of memory so have i done somthing during the insallation that i should have not. By the way I have re installed GX 3 times and done this on many other laptops without problems:smas: Thanks in advance chaps.
Here we go again. I have installed the enviroment files and I have administrator rights but still the same message appears when I try to communicate or go on line with the PLC. The same problem occurs with IEC developer as well.
I have installed the software on another laptop and it works fine ...So it looks like the problem is with the new laptop. I may need a PC expert to look at it for me..maybe there's one in here.. here's hoping.
I use Windows 7 64 bit.
I also encountered this problem if I use a RS-232 to PLC cable.
But if I use a USB to PLC cable then it works fine.
I am so puzzled.
I have wasted a week trying to figure out how to connect an SLC5/03 with my laptop. I do not have and can not Buy the 1747 UIC and PC3 cables. I...
2,569
Hi all, I really need some advice for establishing communication between 1770 KFD with DeviceNet and my laptop. 1. What cable should I use to...
2,484
My Samsung Chronos 7 laptop finally bit it. I know this is an automation forum, but you some smart puppies. It is def. a hardware issue w/ one...
2,958
Hello Everyone, I am being unable to connect my laptop & GE Quickpanel (IC754VGI12CTD) through an ethernet cable. But I could connect the same...
18
6,451
Here my problem. Im prety new with PLC i got some basic but still a beginner. but i got a $%^%$ load of cable and PLC at my work with a laptop...
8,346
