laptop problem
ganutenator
May 2002
kansas
1,440
My Samsung Chronos 7 laptop finally bit it.
I know this is an automation forum, but you some smart puppies.
It is def. a hardware issue w/ one of the video cards. (I swapped the hard drive out w/ the one that was original that I used to switch to ssd and the same symptoms). It only would boot in safe mode. As soon as I deleted the video driver, I can boot no problem, but only in 1024x716.
This laptop was known for problems w/ the video card overheating. Supposedly, it implemented a secondary video card that Samsung's crappy software was supposed to switch over to when gaming, or demand, et al.
I probably exasperated the premature failure by setting every program to use the secondary graphics card.
It would get so hot that I would run an office fan on the laptop.
Question, my thinking is that since I am using a generic windows video driver for the graphics card, that maybe my laptop is just using the built in motherboard graphics card.
Is there some generic windows graphic card driver that would allow me to get up to the native resolution of 1900x600?
specs note my samsung laptop has having a AMD Radeon 6490M
I have wasted a week trying to figure out how to connect an SLC5/03 with my laptop. I do not have and can not Buy the 1747 UIC and PC3 cables. I...
2,572
Hi all, I really need some advice for establishing communication between 1770 KFD with DeviceNet and my laptop. 1. What cable should I use to...
2,493
Hello Everyone, I am being unable to connect my laptop & GE Quickpanel (IC754VGI12CTD) through an ethernet cable. But I could connect the same...
18
6,465
My IT dept' purchased a new laptop for me, a Toshiba Tecra. It has all mod' cons' and a serial port too. Any how they removed Vista and re...
3,356
Here my problem. Im prety new with PLC i got some basic but still a beginner. but i got a $%^%$ load of cable and PLC at my work with a laptop...
8,347
