Graphics issue in Studio5k
ceilingwalker
Mar 2010
Phoenix, AZ
1,586
Hello all. I tried to create a message instruction in RSL5k v.20 and part of the dialog window is cut off. I don't have a ton of experience with these so I am not exactly sure what is cut off. I haven't had this happen for anything else with this software however, it does happen FTView Studio all the time. I contacted AB tech support they said it was a Microsoft issue. I contacted Microsoft and they said it was a Dell (laptop) issue. I contacted Dell and they told me it was a software issue (RS) issue. I am in an endless loop here and hope that someone here might be able to help. This is a screenshot of what I am seeing. Capture.PNG
Under the Windows Display settings, check your scale setting. I always leave mine at 100% and haven't had problems, but several others have had similar issues in FTView when it is higher.
See QA13028 - Access level Techconnect
I personally use workaround 2:
Customers can try to implement the fix described in Microsoft Article (no longer available).
Here are registry changes proposed in this article
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Fonts]
"MS Sans Serif 8,10,12,14,18,24"="SSERIFE.FON"
"MS Serif 8,10,12,14,18,24"="SERIFE.FON"
"Courier 10,12,15"="COURE.FON"
Note: Reboot required after changes have been made.
I assume it should work in Windows 10.
I recall reading this Microsoft Article long time ago and it worked on my computer in Windows 7.
Hello Everyone, I am configuring now a SCADA and needs help with my edited graphics i have edited in Photoshop CS6. Why did I edit a graphic that...
5,722
Dear All, i am new to ArchestrA graphics, I have one issue, where I want to know about the scripts of Archestra graphics in one window. Could...
2,159
I'm having a peculiar issue with my logixpro program. Whenever I open up a simulator it's as if there is another window overlayed on top of...
1,735
Hi guys Ive found this site extremely helpful for logix5000 but i have an issue (hope it can be answered) with citectSCADA7.4. This is my first...
2,013
Hello, I am doing my first ignition project and I am having a bit of an issue with the graphics. The thing is that in the designer, all my...
3,070
