grinding machine Problem
yari
May 2016
Iran-Urmia
Dear Mam/Sir
We have a grinding machine from ELB company that there is no this company nowadays.
Your company’s PLC installed on it and it has a ELB panel connected to PLC.
The PLC model is Promodule –F with three expansion module and the panel is ELB panel (photo1 ).
We have a problem in communication of PLC and panel.
We couldn’t access to ELB company or their service provider so would you please help us to handle the problem.
1. It seems PLC work normal, because some command and machine reaction that no need to panel are OK. (Photo2)
2. It seems panel startup is ok because all LED’s and 7 Segments are on for 5sec and then goes off and then just CPU LED run. (photo3, photo4)
3. All physical connection between PLC and panel are ok.
4. All power supply of PLC and panel tested and they are ok and in range.
5. We checked panel PCB visually and there is no anything wrong.
6. We checked PLC and panel TX and RX data pins with OSC and there is pulse train between them but we found the transmission bitrate is different, PLC TX bitrate is 38400 bps and panel TX bitrate is 19200bps . (photo5, photo6)
What is your idea?
Best Regards
Yari
Rama Electric, IRAN
[email protected]
Sir, We are facing some problem in our RGM (Roll Grinding) CNC machine. RGM MAchine PLC system is SINUMERIC 840C. Drive System is SIMODRIVE. At...
12,367
Hello Everybody Anybody knows where I can get this version of SoMachine? The new machine expert version won't open my project saying there is a...
39
Hello, As part of our project, we are using an M241 controller. This controller interfaces with an industrial computer and a router via a switch...
113
I'm getting frustrated creating arrays of variables in Machine edition. I need to make 2 variable arrays that are 102x2 in size, with varying...
108
Hello, I am still new to PLC programming and I just got this job two year out of school so I don’t remember much. I was given a task were I have...
172
