Ground/neutral
The way I describe neutrals and grounds, in a single phase circuit:
Neutral is where the current flows when current goes where you want it to go. Ground is where current flows when it doesn't go where you want it to go.
"I'm supposed to be the engineer, not the conductor."
We alledgedly have the same colour scheme in Ozz but typically extension leads are brown and blue and the phase and neutral colours are still being run as red white blue black. A bit confusing when blue can be neutral or black and B phase can be white or black. Yellow has not been used for a phase colour for about 15 years.
Yellow and green are only allowed to be used as striped cable for earth and for no other purpose. However, machinery comes in from all over the world and really anything goes.
One has to be very careful when digging around in control panels in particular. I have seen green used as an active in one Chinese machine!!!
Dear Friends, I have an abnormal neutral to ground voltage...around 5 volts at the MCC.How can I find the problem? what can cause this voltage...
2,331
Hi everyone, as this is my first experience with Rockwell Software i would like to know what's the best way to make Enumerations?
594
Hello i can not change one of the displays background color, the "Apply" button is greyed out. the firmware 5.10(older PV PLUS1000). I can change...
1,217
We switched from a SLC5/04 to a 5069-L320ER, and the SLC's NI4's were replaced with the 5069-IY4, which is a pretty neat card; however, the IY4's...
1,777
We have a 753, 75 HP, driving a centrifugal pump, that has been giving us ground faults for months. The drive has load, and line reactors. We have...
19
8,540
