GT Designer 3 Language Default
DamianInRochester
Jan 2011
Rochester NY
1,292
I am using GT Designer 3 on a project I originally did where the customer has since made the application bi-lingual (English and Japanese). All of the text on the screen while in development shows as Japanese instead of English. I haven't been able to find where I can switch things over to defaulting to English. Does anyone else know where that magic switch is?
I was able to find it as well.
At the top of your screen select "View", then select "Toolbar", then select "View". If it disappears from your screen then select "View" again to turn it back on. On that toolbar there is a number with a drop down arrow. Select a different number, mine was "2", this switched the buttons back to English.
I have yet to figure out how to change the screen names to English in the left dialog box.
I've set up a range of comments as well as their Chinese Translations on an HMI. I see the toolbar that lets you cycle through the languages...
1,336
How do I organize the template for my controls. I am new to Logix Designer but have used RS500 and RS5000. My new Logix Designer has Toolbars...
253
Hi, I have questions. I have Analog Input that need to put into Ignition Designer. But I don't know how to put?
131
Good Day all. I am currently busy with a schneider HMI design in vijeo designer and i want to know how you can animate an image to move on the x...
194
Hello, Im building project with 1756-L82ES controller and 1756-IB16S card but i cant find it when trying to add the card to IO configuration...
147
