GT Designer 3 Manual
sttchui
Mar 2008
kl
81
Hi
Anyone know where i can download GT designer 3 manual??
I would like to how to do Monitor Ladder from GT A900 series, i have try to install the OS to the Touch screen communication driver but the error pop up, this is after i replace the A series PLC to Q series PLC. before this it was working for the A series PLC
thank you!
Regards
sttchui
Ian,
you might be able to help.
I'm trying to have a counter count down from 25 to 0
I'm using GX Developer for the logic with GT Designer 3 for touch screen ran through GT Simulator3
What i cant seem do, is have a numerical display on touch screen count in reverse to a timer on the logic. I am new to this and any help would be great.
Regards James
UDCNT1
the numerical input is not the numerical display
I am a bit busy at the moment please try the counter I have listed.
In the logic, you can MOV the counter preset to a register and each time the counter recieves a signal you can use this to DECP the register value. Show the register value on the screen
I worked it out..
Subtract the total amount of time from the timed amount...
eg
as a timer counts from 1 to 25 sec in registry D50
[sub k25 d50 d60]
so
K25 - D50 = D60
25 - 0 = 25
25 - 1 = 24
25 - 2 = 23
25 - 3 = 22
and so on
pure simplicity
love it.....
How do I organize the template for my controls. I am new to Logix Designer but have used RS500 and RS5000. My new Logix Designer has Toolbars...
265
Hi, I have questions. I have Analog Input that need to put into Ignition Designer. But I don't know how to put?
137
Good Day all. I am currently busy with a schneider HMI design in vijeo designer and i want to know how you can animate an image to move on the x...
212
Hello, Im building project with 1756-L82ES controller and 1756-IB16S card but i cant find it when trying to add the card to IO configuration...
173
Does anyone know how to set the background colors of instuction blocks (TON, MOV, etc)?
148
