Yes I understand but you must upload the parameter file so your project contains the information or if you loose your PLC and have to replace it then it will run everything in RAM, not a problem as far as I can see but it would make sense to have your backup synchronised with what is in the PLC. I also suggest you upload the program memory (The "D" registers) this will take a snapshot of the data contained within it, however, I suggest you do this when the system is idle i.e. machine not running.
