GX Developer Dilemma...
Eric Nelson
Apr 2002
Randolph, NJ
4,346
HELP ME GUYS!
I (mistakenly) did an online program change, and now I can get it out of that mode!!! IOW, I can no longer work OFFLINE... banghead
What's the trick to getting out of this mode????... :confused:
GX Developer-FX Version 5.00 with an FX1S
beerchug
-Eric
On, nevermind (again)...
Once again, I'm answering my own questions... :D
I switched to 'online(write mode)' then back to 'monitor', then to 'read' and I'm finally back offline. Switching directly to 'read' seems to cause this mess... :confused:
I guess I should re-read both my "Mitsubishi Sucks" threads again as a reminder to stay away... :nodi:
beerchug
-Eric
Eric, a friend of myne is equiped with finger that look like sausages. Anyway thats what I keep telling him.
I dont have the same version as you but with my version it is
shift/F3 for monitor/write (online edit)
and then just F3 for offline edit.
It warns you it is changing mode but the japlish language can be frightening.
When you run into this problem, it's usually because the "Conversion Writing Behavior" is no longer valid. Okay, that sounds confusing.
Better yet, here's how to solve your problem. Go into options, look at "After conversion writing behavior", select "don't write to PLC". Click OK and you should be good to go.
To enable on-line editing, make sure that the "Write during RUN (while PLC is running)" is selected. I think that this changes automatically when you press "Shift-F3" or select "Online/Monitor/'Monitor Write'.
BTW, I'm using GX Developer v 7.01B
... rab
I'm pretty sure I tried the F3/Shift-F3 method. Perhaps I wasn't persistent enough... :rolleyes:
In any case, I've located the radio buttons mentioned. Not sure why I didn't see them before... :confused:
[attachment]
Thanks for the help guys!... :site:
beerchug
-Eric
I'm trying to verify a project with a PLC. The Transfer Setup menu item is grayed out and every time I click Verify with PLC, I get an error...
75
Well, I've decided to start a new project, and like all projects, it has already gone horribly wrong. I purchased a PLC device (supposedly a...
124
Does anybody have any samples of how to "Create and Use" UDT's in CCW Developer Edition? (I am using v22) I can't find any information from...
329
I'm trying to manually convert a Beijer E200 HMI project onto to a new Mitsubishi GOT gs2107-wtbd. The PLC is a very old A-series AS1CPU and is...
395
Hi One of the PLC's that I maintain/update is a Mitsubishi Q-Series, probably installed about 10 years ago. At the moment, ALL the wires from...
1,194
