GX developer: What's the difference between 'Insert Line' and 'Insert Row'?
Mas01
Oct 2020
Leicester, England
1,109
So far, for adding new rungs I've been using INSERT LINE, but I notice that INSERT ROW is also in the drop-down list.
So, what's the difference? Seems ambiguous, to me.
Edit: Another question: STATEMENTS are limited to 64 characters. Can this be increased?
Looks like you're right!
By looking at that probably not, if you were asking what would happen if you removed an output card when powered then fair enough but this sort of thing is about learning, just have a crack and see what happens...
Agree. print out 10-15 pages of logic and have a go and typing them into a dummy project and learn the basics of the editor
I've always used ,shift insert.
And for your info, ctrl and insert moves everything right from where the cursor is so you can fit an extra bit in the line.
As per the title. This might seem like a basic question to many, but I'm unclear about the difference between a coil ( ) and an application...
28
4,062
I'm trying to verify a project with a PLC. The Transfer Setup menu item is grayed out and every time I click Verify with PLC, I get an error...
64
Well, I've decided to start a new project, and like all projects, it has already gone horribly wrong. I purchased a PLC device (supposedly a...
117
Does anybody have any samples of how to "Create and Use" UDT's in CCW Developer Edition? (I am using v22) I can't find any information from...
323
I'm trying to manually convert a Beijer E200 HMI project onto to a new Mitsubishi GOT gs2107-wtbd. The PLC is a very old A-series AS1CPU and is...
390
