gx developer
lab
Nov 2003
48
I'm new to the Mitsubishi line of plc, I'm programing a FX1S-14MT plc using gx developer v8.07, I have upgrade to just the last little while and am wondering how to start my gx simulator program, it was installed , does it run through gx developer or is it it's own program?
Thanxs in advance
Best Regards
Lab
Run LLT through GX-developer. Try Tools-menu=>Start ladder logic test and stop from the same Tools-menu. Button to LLT is in program toolbar (last).
Full? monitoring and bit-tests are awailable in you case, I think.
Tmu
You run GX dev AND have a project open.
If the simulator software is installed there will be a blue button to start the simulator.
The software then simulates as if a real PLC was connected to your PC.
You have to do exactly the same things for uploading/downloading as you would with a real plc.
I have that icon and it is high lighted, but when I press it I get an error, "failed to activate ladder logic test" is my simulator software corrupted?
Thanxs in advance
Best Regards
Lab
Have you tried to uninstall it using Windows add-remove sw: GX simulator and re-install it? :confused:
I just install that simulator ver 6.0 (after installing) GX -Dev without any problem.
Tmu
I'm trying to verify a project with a PLC. The Transfer Setup menu item is grayed out and every time I click Verify with PLC, I get an error...
53
Well, I've decided to start a new project, and like all projects, it has already gone horribly wrong. I purchased a PLC device (supposedly a...
112
Does anybody have any samples of how to "Create and Use" UDT's in CCW Developer Edition? (I am using v22) I can't find any information from...
313
I'm trying to manually convert a Beijer E200 HMI project onto to a new Mitsubishi GOT gs2107-wtbd. The PLC is a very old A-series AS1CPU and is...
382
Hi One of the PLC's that I maintain/update is a Mitsubishi Q-Series, probably installed about 10 years ago. At the moment, ALL the wires from...
1,171
