GX IEC Developer need urgent help with high speed counters
AndersW
Jan 2010
Sweden
24
Heya everyone thanks for reading im stuck with a project im doing at work and cant find the problem :(
I have an mitsubishi FX3U system connected to a E1032 beijer HMI
to the FX3U i have a pulse sensor connected to X0, I run a highspeed counter and a highspeed compare but by the looks of it the high speed compare doesnt react when the value is reached
Also I got 1.865 pulses/mm but the PLC doesnt seem to accept commas? or do I have the wrong format on the register?
Pictures either below or attached, not really used to posting here yet and once again thanks so much for reading this thread
Err i just found an old example parky posted on these forums and he uses CS236 is that the error ive done since im using CC235?
Also he uses DWORD to specify the CN235 and I use DINT whats the difference between the 2?
his program is for an FX1N i think might be that it doesnt work on mine?
So i sorted my highspeed compare function out but i still havnt been able to figure out how to multiply with a decimal value
Ive made 3 registers with REAL
D0 D1 D2
what i want to do is
D0-D1 and then take the new value and multiply with D2
the D2 value is 1.865 but the plc wont let me set it to that
so i got a sub D0-D1 ---> Mul D2 ---> real to int > D3
all ideas are appreciated
Anders
Hi everyone, I'm working on a Mitsubishi Q series PLC whose code was developed in Mistubishi's GX IEC Developer v7.04. I looked online for GX IEC...
1,495
502
Hello, i want to do a device backup but can´t find it. Someone remembers? :huh:
883
I reposted this as I had mistakenly put IX developer in the title (it was a long day) :zzzzz: I have a policy of always verifying code before I...
1,473
Hey, I have a small problem that I hope someone here could help me with. I'm trying to set up a transparent mode so I can monitor my program...
1,874
