Transparent mode GX IEC Developer - E1101
Erki
Feb 2016
Sandviken
Hey, I have a small problem that I hope someone here could help me with.
I'm trying to set up a transparent mode so I can monitor my program while I'm trying it on my HMI.
Now I got (PC)--RS-232--(PLC), when I transfer the program. And when I use the HMI, I have to switch the RS-232, so, (PLC)--RS-232--(HMI).
Is there anyway I can use (PC)--ethernet--(HMI)--RS232--(PLC) ?
I've asked the programmers around me, but no one seems to be able to make it even when we follow some basic instructions, maybe it's not possible?
PLC - MELSEC, Q61P-A2
HMI - E1101
GX IEC Developer
E-Designer
This are the programs that I'm currently using.
Please, I'm tried being a 0, make me 1.
http://www.beijerelectronics.com.tw/web/web_en_be_tw.nsf/alldocuments/CB389E02C3FAA5C4C12579BF004522E2
I would try to have the HMI communicate ethernet to the PLC. This way the rs232 port will be available for programming.
Just a thought,
Yes, I agree but I got a old PLC that was just about to get thrown away, and it doesnt have a ethernet port on it.
Anyways I managed to solve the problem with "Serial/IP" program, it was only that part I was missing from start :mad:
Thanks anyways :geek:
Hi, I am using CM_CAN in my project in Transparent mode. The CAN modules needs transmit 240 message definitions each of 8 bytes, 168 message...
67
I'm trying to manually convert a Beijer E200 HMI project onto to a new Mitsubishi GOT gs2107-wtbd. The PLC is a very old A-series AS1CPU and is...
383
I am asking on here in case anyone has come across this before. I have also asked it on mrplc.com to try reach a wider audience as I am a little...
2,212
Hi, I am trying to get transparent mode working with an E1012 and a FX3G plc. We have had no problems using a FX1N but no joy with the FX3G. Cable...
3,793
I cant seem to get the transparent mode to work. I have a Mitsubishi (Beijers) E1101 connected to a Q02 CPU on RS232. I then have my laptop...
3,975
