H2-CTRIO module with Direc Logic 205 PLC
mahsaman
Feb 2012
USA
Hi, I am trying to use a high speed counter with a Direct logic 205 PLC with DL-240 CPU. This is the first time that I want to configure and use this module in PLC program. I just went through the manual to see how to configure the module. But I don't know how to program the PLC. I am using this module with a steppe motor to have different position of a shuttle. This is used for a cutting machine. Can anybody help me? I am not sure if I have to use quad counter as the input and pulse (step/dir) as output for the module.
Thanks.
H2-CTRIO module
Can anybody send me a program example for a cutting machine? I use this CTRIO module with a stepper motor, which is connected to a shuttle. I need this shuttle go to different positions in a line and in each position a cylinder comes down and cut an object.
Can anybody help me please
Hi, I am trying to learn how to use my encoder with my PLC. I recently got a high-speed counter module (H0-CTRIO2) for my DirectLogic05 PLC. I...
2,224
Hello team, I am using H0-CTRIO High Speed I/O module with DL-06 PLC. I have to rotate 2 stepper motor in my application. The Stepper drives are...
1,639
I have a H0-CTRIO counter module mounted in slot #1 of a Automation Direct D0-06DD1. I want to be able to change the preset of the counter via a...
5,001
Hi there, I have a vision project on that has been through some pretty major paradigm shifts since its inception. Without getting into too many...
3,997
Hello all, I have come up against an issue trying to run a stepper motor using an Automation Direct H2-CTRIO2 module. Simply speaking, my setup is...
2,685
