Hard time Opening Factory View Studio to see Tags
Thanks again for more info on this subject George. I guess I was under the false impression that MSSQL was only used on 64 bit machines. My understanding must have came from when it was first introduced in v6.1.
1. Go to C:\Program Files (x86)\Microsoft SQL Server\MSSQL10_50.FTVIEWX64TAGDB\MSSQL\DATA
2. Delete the modellog.ldf and the model.mdf.
3. Browse to the following folder: C:\Program Files (x86)\Microsoft SQL Server\MSSQL10_50.FTVIEWX64TAGDB\MSSQL\Template Data
4. Copy the following two files: modellog.ldf and model.mdf.
5. Paste the two files in the folder located at: C:\Program Files (x86)\Microsoft SQL Server\MSSQL10_50.FTVIEWX64TAGDB\MSSQL\Data
6. Reboot
7. Restart SQL Server(FTVIEWX64TAGDB) under services, if not started
Quick pit stop...
Hi Hansie and welcome to the Forum!
Your shared information is most welcome but I would advise you not to copy/paste directly from the Rockwell Knowledgebase. Rather, link the article instead, as I will now demonstrate...
Here is a link to the technote which contains the first step I mentioned earlier in this thread of checking the FTVIEWx64TagDB Service is running...
465364 - FactoryTalk View: SQL Server 2008 Express Instance FTVIEWx64TagDB... cannot be found
Access Level: TechConnect
...and the second step kindly provided by Hansie above. There is also a third scenario covered where the current MSSQL package has been unintentionally uninstalled while installing newer Rockwell software which installs a newer version of MSSQL.
Regards,
George
6. Reboot
Thank you!!
I works for me.
For step7, go services.msc ---> SQL Server(FTVIEWX64TAGDB)---> Start Service.
Hi All, I have had a little search through the archives but I cant seem to find anything on this issue (surely I cant be the only one to have...
2,902
Hi - I'm a newbie to the PLC world but was recently asked if we could store more than the 2G that the CompactLogix 5370 allows by its max size SD...
1,337
It's Saturday, so I thought it would be amusing to look at times gone by, imagine if you had to carry this to site "IBM 5mb Hard Disk 1950's.
1,868
Any help appreciated, Proposed question: I need to track parts to count the rejects in a rotating machine but having no luck tracking proper...
2,352
I've been beating my head against this problem intermittently for a while now. :banghead: We have 3 meter with hard mechanical counters on the...
26
7,919
