Hardware in the Beijer IX-series rebranded?
najsel
Aug 2011
Stockholm
Is there anyone that has any clues around the hardware for iX-plattform? Is it rebranded or self developed? I have some clues that the hardware is rebranded and manufactured in asia. Does anyone has some idéas surrounding this?
Specs around the panels:
Display TFT-LCD. 640 x 480 pixels, 16.7 million colors (true color).
LED backlight
Screen size 10.4"
Active area of display, W x H 211.2 x 158.4 mm
Brightness (cd/m2) 450
View angle (H) / (V) 60/80/80/80 (U/D/R/L)
Back light lifetime 50,000 h
Touch screen operations 1 million finger touch operations
N/A N/A
LEDs 1 x blue
Frame material Powder-coated aluminum
Front foil Polyester Autotex F157 or F207
Front panel seal IP 65
Rear panel seal IP 20
N/A N/A
Processor 400 MHz ARM9
N/A N/A
Application memory 80 MB
External storage media 1 x SD card (optional)
Real time clock Yes (on chip)
N/A N/A
Power consumption at rated voltage Normal: 400 mA
Fuse Internal DC fuse, 2.0 AT, 5 x 20mm
Power supply +24 V DC (16-36 V DC), max 2 A.
CE: The power supply must conform with the requirements
according to IEC 60950 and IEC 61558-2-4.
UL and cUL: The power supply must conform with the requirements
for class II power supplies.
Operating temperature -10° C to +60° C
Storage temperature -20 to + 85° C (depending on display)
Relative operating humidity <95 % non-condensed
N/A N/A
I´m pretty sure that it´s self developed…
The hardware is developed by Beijer in Germany (by a German company that Beijer bought for a couple of years ago), I think the design is made in Sweden as well as the software…
I have an 1769-L16ER that I use to test code and I just found that I can't create MSG tags at the local program scope - they have to be done at...
202
Hi all, This is going to be a long post apologies. I'm also a complete beginner to the world of PLCs. I'm currently working on my first ever...
474
Greetings All, I recently decided to start freelancing in Controls and Automation part time, most of my experience has been with Rockwell...
164
hello, I am using Beckhoff with TwinCAT3 and when I change or add some new hardware or for any reason, there is a mismatch in the real hardware vs...
136
I've ready through the the previous posts, and we've worked with safety design for a long time. In the past, we worked with Pilz directly, and...
600
