Hardware Problem
Daffi
Mar 2013
Ireland
Ok, I'm in a bit of a bind at the moment. I'm in my final year at Uni and doing my final year project, mostly everything is done, coding, wiring etc, except i'm after hitting a problem. I'm trying to communicate from a Siemens S7 300 to a Norgren Profibus DP VE2. You see, the 9 pin D-type connector came off the end of the cable which was attached to the PLC, going into the profibus was a 12 pin coinver type connector. Both are obviously numbered but i'm finding it hard to find anything on the net with regard to correct pinout and assembly, as i intend to solder the 6 wires in the cable myself. If anyone has any information, it would be greatly appreciated.
I have also cotacted Norgren and looked up appropriate manuals but to no avail.
This article guides you through troubleshooting steps for hardware and software driver problems in Windows XP. There are many reasons why you might have a hardware or software driver problem. You might have installed an update that caused your driver to stop working.
Hi guys, i just got my hands on a siemens s7-200 226 cpu (code 6ES7 216-2AD23-0XB0), dc/dc/dc now i tryed to power it up by plugin in the +24v...
1,261
Hi guys; i want to simulate a hardware interrupt in s7-300 with PLCSIM. i configured a CPU300 (not compact) , a DI card with interrupt...
1,881
Hi ! Grettings of day i am using s7 400 plc and i want to replace hardware of ET200L 16 bit module to 32 bit module , when i try to replace it...
2,144
Hello, I face with a problem when I try to getting online to CPU 315-2dp (315-2ag10-0ab0-V2.0.8) using Step7 V5.4. I can upload...
3,556
Hi guys, I'm currently working with a siemens PLC 314C-2DP and am using the fast counter input(channel 2) with an incremental encoder...
5,163
