Hardy 6600 Series Zero with No Hardy Controller
Ryan_Flowers
Feb 2019
Las Vegas
57
Hello,
I have a set of three tanks with their own trio of Hardy 6600 series load cells. Two of them have no issues with where they are at and applying weight during a calibration was within tolerance. The last one has a negative value in the gross and net weight. This value goes up properly when applying weight, but obviously the program errors out with those values and shows zero at the HMI. I have used these types of loadcells in the past and their controllers to zero, tare, and hard calibrate. Problem is between the load cells and analog input card, there is no controller that I can find for any of these groups of loadcells. This does not allow me to zero from what I can tell. My question is; Does anyone know of a way to zero these values without a Hardy controller? There does not appear to be a command in the HMI or PLC logic that accomplishes this.
See attached photos of problem tag and the other that is working normal.
Thank you in advance for your assistance.
I used to have something like that, I had 4 weigh stations with 4 load cells each.
Attached you will find a way to tare each station I included only two of them, please go to hardysolutions.com , there you will find all the manuals and examples.
  • hi6600 Rslogix 5000 integration.pdf
Thank you.
I ended up going to HI6600 - Weight Processor Modular Sensor System , then using the Quick Start and HI6600 User Guide Book to change my TCP/IPv4 to the appropriate network and node. I was able to get to the settings and operations to zero via a web browser.
Good to know you can execute these commands this way instead of needing a Hardy interface.
Hi 3 Cells connected to a summing board, then to the series b hardy weigh module then connected to device network. Can not calibrate the cells...
2,585
Does anyone have any idea when the Micro850 will be coming out? The last note I saw on it on this forum was from June of last year.
3,875
Does Any one have a program for Logix 5000 for this card. the one from Hardy is not that great and is a little hard to follow. Thanks for any...
2,331
Does anybody know what material I will need on the PLC side to communicate with a Hardy controller ? Hardy says Ethernet/IP, Modbus TCP...
2,378
Hello I am trying to configure a hardy 1769-ws scale card for a micro logix 1500 and the manual is tuff to understand does anyone have a better...
1,880
