HC 900 Range FB
_V_
Aug 2023
Portugal
31
Hey guys, what is the function block that you guys use for range value ?
I want to turn off a valve when a analog value is between 2 and 50, what FB do you guys use ?
I am using hc900 honeywell PLC.
Thank you !
Thank you !
ORing the results of an HMON (cf. here) and an LMON would probably be the best from a "what is this doing?" aspect three months from now, and so is probably the best option.
HLLM (cf. here) is another optionl it would require ANDing the H and L output pin results, but might read nicely.
DCMP cf. here; i.e.
  • Y = input analog value
  • IN1 = 2
  • IN2 = 50
  • Internal configuration
    • Plus Deviation = 48
    • Minus Deviation = 48
I think that works. It's a little obscure, so it's good for Code Golf but I am not sure it belongs in production.
Can you explain how ?
I try to use the HLLM and when I put the limits it didn't range nothing.
And in the O Ring I put between 2 and 28, then 32 and 95 and it didn't turn off.
What do I want is, I have a valve and it gives me a value, and when the value is 0 25 30 or 96 it turns on a variable, but when is like 2-28 and 32-95 it turns off the signal to the variable. So I think I have to put a FB that when in that range it turns off.
This is not clear.
Originally you wrote that values between 2 and 50 would assign a value of 0 to a bit ("turn off a valve"), so presumably values
  • EITHER less than 2
  • OR greater than 50
will write a 1 to that bit.
But now you write
25 => write a 1 to the bit ("turns on"), but 25 is in the range 2-28 => write a 0 to the bit ("turns off").
0, 30, and 96 are all outside those ranges, so they would write a 1 to the bit ("turn on").
Is the 25 a typo?
off = (v > 2 AND v < 28) OR (v > 32 AND V< 95)
on = NOT off
De Morgan:
= NOT ( (v > 2 AND v < 28) OR (v > 32 AND v < 95))
= (NOT (v > 2 AND v < 28)) AND (NOT (v > 32 AND v < 95))
= ((NOT (v > 2)) OR (NOT (v < 28))) AND ((NOT (v > 32)) OR (NOT (v < 95)))
= ( v < 2 OR v > 28 ) AND ( v < 32 OR v > 95))
Associative property [(a OR b) AND c => (a AND c) OR (b AND c)]:
= ( v < 2 AND (v < 32 OR v > 95)) OR ( v > 28 AND (v < 32 OR v > 95))
Associative property again, within each term on either side of the central OR:
= ((v < 2 AND v < 32) OR (v < 2 AND v > 95)) OR ((v > 28 AND v < 32) OR (v > 28 AND v > 95))
Drop redundant parentheses:
= (v < 2 AND v < 32) OR (v < 2 AND v > 95) OR (v > 28 AND v < 32) OR (v > 28 AND v > 95)
( true if v < 2 ) ( cannot be true ) ( cannot simplify ) ( true if v > 95 )
= v < 2 OR (v > 28 AND v < 32) OR v > 95
In HC900 FB:
______
[LMON ]
v-[X OUT]-------------------------+
2-[Y ] |
------ | _______
______ _______ | [4OR ]
[HMON ] {2AND ] +--[ OUT]---
v-[X OUT]--------------[ OUT]-----[ ]
28-[Y ] +--[ ] -[ ]
______ | | -------
[LMON ] | |
v-[X OUT]-----------+ |
32-[Y ] |
______ |
[HMON ] |
95-[Y ]
Or, to replace the HMON/LMON pair for 28<v<32 with an HLLM:
______
[LMON ]
2-[Y ] |
v | _______
__|___ _______ | [4OR ]
[HLLM ] {2AND ] +--[ OUT]---
[(32) H]--------------[N OUT]-----[ ]
[(28) L]--------------[N ] -[ ]
(unused) |
______ |
[HMON ] |
95-[Y ]
I'm upgrading an existing machine with a Honeywell HC900 controller, and I'm trying to do some data processing in the controller. I have variables...
56
Hello everyone, My designer software as the 7.200 firmware, but when I go to download to the plc HC900 from honeywell the program I created...
665
Hello, I have an old project i did 2 years before, now i need to make a few changes but somehow i cant seem to connect to my hmi. I could access...
957
Hello everyone, In the designer softwar of the plc HC900, I used the function version control on the toolbar and it deleted files from my...
355
Hey Guys, I am getting random rack/slot errors. I go to download and everything is ok but then it has a error. For example - Yesterday everything...
369
