Heads up, Modbus Guys
danw
Oct 2004
midwest, USA
3,428
I stumbled onto two noteworthies from Chipkin's web site
1) A free Windows app Modbus master, the does the normal read/writes in various formats, but also claims to scan a network for Modbus slaves. Hmmmm. That could be nifty. Details, description and download at the link below
http://www.chipkin.com/cas-modbus-scanner
2) The site's newsletter has an article on Skype grabbing serial ports, even when Skype is not active. The article recommends a free utility, Process Explorer, for killing Skype's greedy paws. (Process Explorer is a download from places like C-net)
article:
Skype Prevents HyperTerminal From Using Com Port
Sometimes Hyperterminal tells you the port is in use even when you think it is not. Skype likes grabbing your com port especially COM1. When you try to use the port you can't, even after you quit Skype. To remedy this situation, use Process Explorer to find and kill any process using the com port because Skype is not the only offender.
Steps:
1.Download Process Explorer.
2.Unzip and Run the process explorer.
3.Select FIND.
4.Type: serial.
5.You will get a list of processes using the serial ports.
6.Kill them.
An alternative solution:
1.Go to the Control Panel > System.
2.Disable COM1.
3.Reboot and then re-enable it.
http://www.chipkin.com/december-2011-newsletter
Thanks, Dan! That Modbus scanner will come in very handy. I used a similar program recently, but it was only a trial program, so it expired. Free is ALWAYS good!... (y)
-Eric
I've used Chipkin's Modbus "parser" extensively; if you're doing a Modbus decode by hand it cuts your work down by 80%.
I cannot figure out why Skype would want to use a serial port, though. Maybe Skype handsets like to emulate COM ports.
I’ve used the Chipkin scanner for a year or more now, it’s evolved a bit and gets better each time. it’s very handy for checking data addresses as some equipment manuals are not always straight forward.
It’s also free and I like free stuff that works
Chris
I've used this scanner before as well and I appreciate the fact that it's a free app. Look for upgrades often those--anytime they do one, it's worth the download.
Anyone still using this?
article:
Steps:
3.Select FIND.
4.Type: serial.
6.Kill them.
2.Disable COM1.
Is this the cause of the "ComPort not Connect !" message? Other serial programs do not complain about the port, but this one does. I am using a USB to TTL rs485 adapter and also a usb rs485 adapter. Same problem with both.
Good Evening , We have had a problem with some broken I/O wires on a Fanuc Robot. I'm sure we just need to rerun some cables , but I was...
1,646
I am investigating the possibility of virtualising a Centum HIS station in vmware. Assuming i can successfully install a Vnet\ip card in the...
1,680
Working in an industrial environment all my life I have often been amazed at the ingenuity and skills of some engineers. Many times I have...
2,690
  • Poll
Here's a poll. Seems like there are more and more controls guys in over their heads. Maybe it is just locally, or regionally. A lot of mechanical...
39
13,829
The older guys will appreciate what my company does repairing dinosaurs. We deal with 20 year old plus PLC's and other automation equipment. We...
2,520
