HELP!!!!!!! can someone look ove my project
chbryan34
Jul 2010
US
I have attached what I came up with
A room must be maintained between 20 and 30 degrees C using a combination of an AC and Heater, four thermostat: T20, T22 ,T28 and T30. If the temperature reaches 30 C, which activates T30. the AC must be energized and kept until the temperature decreases to 28C which deactivates T28. If the temperature reaches 20C which deactivates T20, the heater must be energized and kept energized until the temperature increases to 22C which activates T22. A master switch must be turned on for both the AC and heater to operate. Use latch and Unlatch instructions, Assign sequential addresses to the input and output starting from bit 0
Close. Since this seems like a class test / exercise, the only thing I'll comment on is why are you using all N.C. thermostat contacts in your logic?
chbryan34,
you have made an effort to do the program, posted your work, and askksed for help.
the dave2 has given you a clue in regards to your program.
this was an attempt to get you to think abou what you've done.
take your program, and what you put on the website.
sit down and read what you have typed.
work out your logic line by line, not all at once.
regards,
james
If a programmable controller controls the operation of a motor, what connects motor control to the PC? A) Line voltage B) I/O device C) Modem D)...
27
7,147
Hi all, Am new here, normally I work on OSAI and Beckhoff systems but I have a problem with some Indramat dkc11.3 drives that all display the...
1,425
i have a project that i need help designing. i go to college but we only get 2 hours a week to work on the computer that has the plc program. i...
2,423
Hi, i uploaded program from Allen Bradley PLC, i need someone to help me elaborate more on this uploaded project will appreciate any help thanks
2,139
Hi Friends ! I'm having a little challenge here, I'm almost done in my conversion project from panelBuilder to Factory Talk. I really need a...
1,593
