Help! Configuring Alias Topics in RSLinx!
Jun 2015
Moscow
Hi there, I have little annoying problem with configuring Alias Topics in RSLinx Classic Gateway. I created two drivers for each PLC in redundant pair, then created topics and alias for that topics. The problem is that I can't get any data from this alias topic. Everything I can see in OPC Client is data from each topics but not from alias topic.
I'm using RSLinx Classic Gateway.
In conclusion, I can't get data from alias topic in RSLinx.
Screenshots attached.
a) Maybe you need to install a hotfix for RSLinx. You need to provide more information about versions.
b) I'm just wondering if you are building this alias to keep the communications in case of a switchover. Remember that IP addresses are interchanged during a switchover; that means you only needs to point to the master controller.
Thank you! I really didn't know that I need to point just to the master controller. Now it's all clear.
Actually I develop SCADA HMI and that's why ask about simple things like this.
Hey guys, I recently had to change out an old eaton drive from our WWTP with a newer DG1 Eaton drive. I had to install a DXG-Net-Device net...
3,749
Hi all, Now I am working with Sicam P50 multi function meters. It have 2 sets of Analogue outputs. I want to know how we can check its working or...
1,514
Hi, I am fairly new in the PLC industry, and my latest job for me to complete is to test a panel with a single output module (Spectrum Control...
1,767
I have to load a project to a PLC 5 processor via DF1 protocol. I have a laptop with a PCMK card in it with the 1784-PCM5/B Cable. I have to...
2,352
I would like to seek assistance on configuring the G File on Backup Scanner 1747-BSN for the following setup Rack 0 (Where the Main [2 x CPU SLC...
1,872
